And I’ve noticed errors in the guide again; for example, if you look closely, they’ve drawn both of the final cases the same way.
The top case doesn’t have a protruding tab; instead, it has a slot underneath that fits over the dark one.
This is what I hate most about this kit—the stickers on the wood keep peeling off! I already complained about this in a previous post, but honestly, the whole kit is like that.
You need to use the cases as a guide for positioning these strips, but if you look closely, the placement marks on the adhesive strip aren’t visible at first glance; well, I’ve found a trick to spot them, in case it helps with your build.
Great progress for day four! That sticker trick is really clever, especially for those tiny placement marks that are so hard to see. Thanks for sharing it, and hopefully the guide errors and peeling stickers get easier to deal with as you continue. Looking forward to the next update!
