Thank you!
For me, some parts were easy to build, some were not particularly making the hole using the precision knife since I’m quite perfectionist.
Thank you for the compliment!
I appreciate it a lot. ![]()
Thank you for your kind words! ![]()
The thing is, that the hole will likely be out of sight once you add furniture.
@serenebliss_23 your welcome hun ! ![]()
You’re most welcome! ![]()
Yes, it tested my patience.
I wish that the hole and paper were pre-cut.
Hello, we messed up on this part and pasted the paper to the wrong side of the floor. Is there any way to get a copy so we can print and start over?
Hello.
I will try to message Robotime if I can get a soft copy.
It’s coming together so nicely!
I think you did a great job with the flooring. Cutting those tiny openings neatly is never easy. Sanding the front wall was a smart fix too. Sometimes a little adjustment makes all the difference. I can’t wait to see the Teddy’s Bread Box once all the walls are in place. It already looks so cozy! ![]()
You did amazing! You cut it so neatly. Thanks for the tips
I’m so excited to see how it would finally turn out.
@King_Corder welcome to the community! Pasting a paper piece on the wrong side is the kind of mistake many builders understand immediately. Hope someone can help you find a printable fix so Teddy?s Bread Box can keep moving forward.
I will post my progress here soon.
Thank you for your sweet words!
And you’re welcome.
You are always welcome! ![]()
You’re welcome. I’m excited.
