It’s great! I used it to make some tiny wood pieces that were missing in the kit. One of the pieces needed a hole drilled into the center. I’m having so much fun!
Great idea! thanks for sharing this tip. I have one but never used it to one of my builds
Is that a drill? Just curious, what are you using to hold the miniatures when you’re drilling them? I haven’t tried one yet and I’m afraid to cut my fingers. ![]()
I’ve used it several times for this build. I’m getting better at using it.
@serenebliss_23 yes, it drills and has sanding wheels. It also has saw blades to cut wood. You can use a mini vice to hold things but so far so have only used my fingers.
Oohh I think I will be afraid if I’m the one who will be using it since I don’t have an experience with it yet. Thanks for sharing though. ![]()
@serenebliss_23 I had zero experience with it when I got it. This build has caused me to use it quite a bit and I love it.
Ohh that’s nice. I thought you already have an experience. Maybe I will give it a try one day.
@serenebliss_23 I have confidence in you…you’ll do great with it!
Aww thank you for the kind words. ![]()
I’ve found most light fittings need to be threaded from the bottom up.
@Farsideb yes, that’s true, but this particular fixture had a hole too small to fit both wires into.
