👍 [Beginner Tips] “Elastic wood parts”
Don’t know what else to call them. You know the pieces that are cut partway through so that they will bend. Put a piece of tape on the back before you work with it and it shouldn’t break so easily.
Ahhh that is good to know and worth a try!
That’s a good tip. Will do that. Thanks for sharing.
I also find that flexing them back and before before trying to install them helps. I also and and wax the tabs that are being inserted. Slight stretching also helps.
Is this the pieces of wood with bendable design? Yes. I was able to do that and the tape in really helpful. But you still need to be careful.
That’s a nice idea! I’ll keep that in mind for future builds. Thanks a lot for the tip!
Oh that’s a nice idea! I have yet to break one but they’re hard to work with. :crossed_fingers:
That is a good idea. I always tend to break those part.
I’ve seen people say that…curious to know if it really helps.
great tip
Thank you for sharing helpful tricks. :blush:
Another great tip. I have been lucky so far with the bendy bits but it never hurts to have a trick up your sleeve.
I have heard this before. I also heard steaming the wood helps.
That’s a really helpful tip! Thanks for sharing, those bendy pieces can be so tricky!
Thanks for sharing this tip :hugs: I will try it next time
That is a good tip, thank you :clap:t2::folded_hands:t2:
